Hi, I’m trying to see if Heltec might be the right product for a need we have - a basic device that will sit asleep (potentially for months) but transmit if moved or disturbed. I see there is an MPU9250 board available, but a search of the docs gives no results for ‘MPU9250’ or ‘accelerometer’. Would my use case need me to code from scratch (Arduino?) or is there a prebuilt configurable firmware? (I have found the demo https://github.com/HelTecAutomation/ASR650x-Arduino/blob/master/libraries/LoRa/examples/LoRaWAN/LoRaWAN_Sensors/LoRaWan_MPU9250/LoRaWan_MPU9250.ino, but this is a simple scheduled send not interrupts). Sorry for my uselessness - all help very much appreciated.
MPU9250 'shake to send' example
hi
you can configure the MPU9250 to change the interrupt pin on a defined event like movement.
than you can have a look at the interrupt example for LoRaWAN.
Combine them and add code for configuring the MPU interrupt.
Thanks - that’s how I hoped it would be. I will get some boards and have a play - you don’t sell the accelerometer board yourself?
right now we dont have the MPU9250 for the capsule in stock.
Hi Nashenden,
Did you ever get this “Shake to send” to work and if so could you please post the code?
