Just curious if any has a good mounting solution for the capsule. I am using the mop holder but the stainless steel blocks a good bit of the signal.
Mounting of the capsule solar
cable ties? I don’t have a better idea.
I found it on the internet. Hose clamp
I found these command strip mop holders work pretty good and since they are plastic they don’t block the radio signal… Not sure how long they will last in the sun though 16139908556626362293795854393415|375x500
