Hello, I am working with an MLX90614 sensor and the WIFI Lora V3. When I want to see the data read by the sensor on the integrated OLED of the LORA V3, I cannot. But if I do it separately I can. It would be a great help if someone enlightens me the way. First of all, Thanks.
MLX90614 and WIFI LORA V3
Use idle pins and then use two different sets of IICs, such as wire and wire 1
It would help if you posted your code so we can see what might be the problem.
