MeshTower V2 microSD pinout request
Hello – I have (7) of the new Meshtower v2 1w repeaters (and they are great so far). Running Meshcore.
I am looking for the microSD card wiring information for the newest MeshTower V2 hardware revision that is now shipping with a microSD card or microSD socket. Could you please provide the GPIO assignments for:
  • SD SCK
  • SD MOSI
  • SD MISO
  • SD CS
  • SD card detect, if used
  • SD power-enable pin, if used
I would also appreciate an updated MeshTower V2 baseboard schematic or pinout document showing the microSD circuit. The current Meshtastic MeshTower V2 variant only documents the LoRa SPI pins:
  • SCK: P0.19
  • MOSI: P0.22
  • MISO: P0.23
  • LoRa CS: P0.24
It does not document the microSD connection. Please confirm whether the microSD card shares the LoRa SPI bus or uses separate GPIO pins. Thank you.
Take a look at these two commits … https://github.com/tonycowan/Prns/commit/74a8aa368 and https://github.com/tonycowan/Prns/commit/8b56c82f3
It’s just some early debug testing, but it shows reading/writing the SD card and then flashing from the SD.
