Mesh Node T096 external GNSS antenna problem
I have a problem using an external GNSS antenna on Mesh Node T096. When the resistor is not moved to use the IPEX interface, I’m measuring 3.3V on the IPEX connector as it should be. When I move the resistor to use the IPEX interface, the voltage drops to 1.14V, which is not enough to power the active GNSS antenna.
Can anyone help me find out what is the problem?
Thanks,
I think I found the problem. It is not a resistor as mentioned in the documentation it is a 100pF capacitor and I just short circuit it. It needs to be corected on the webpage.
