Hi, I successfully run a sketch derived from your example to measure battery power (https://github.com/HelTecAutomation/Heltec_ESP32/blob/master/examples/ESP32/ADC_Read_Voltage/Battery_power/Battery_power.ino).
I have some questions about this:
I measure port 36 (Vin about 150 to 170 mV ) and 37 (Vbat, between 2000 and 2800 mV). Vbat is the battery voltage. But what is Vin on port 36?
In the documentation it is mentioned that GPIO 21 controls the battery voltage towards pin 37 and Vext. In the sketch I do not see code to set or reset GPIO 21. Why is that?
Thanks,
Fred
