Hi all,
may I kindly ask what is the maximum sleep time for Cubecell board. In ESP it’s apprx. 72minutes. Is there any kind of such limitation?
Lukas
Hi all,
Lukas
the dutycycle is stored in an uint32_t variable.
this type of variable can store a value up to 4294967295.
due to storing the dutycycle as a ms value the max time is 4294967 seconds.
4294967 seconds = 71582 minutes = 1193 hours = 49 days
the longest dutycycle i have ever used with the cubecell was 1 hour.
Hi, really appreciate your quick response.
My use-case: parking sensor which measure the presence of car (geomagnetic), if there is a change of existing status, then the sensor initiate the cube cell wake-up to report the actual status via lorawan. If there is no change for long time, I just want to wake it up by timer (at least 3 times per day), only in case to send a new register values (like sleep time, sensor calibration command, …).
