Map tiles on expansion kit?
I bought the Heltec v4 expansion kit a month ago and I still can’t figure out how to load map tiles. Has anyone added a sd card module to be able to add a reasonable amount of maps and other offline info.
My intentions with the expansion kit was to use it for offline maps and communication. The whole point of the screen, to me anyways, was to be able to view the node map and find my other nodes as a standalone unit as advertised.
Is there any b2b options in the works?
https://buymeacoffee.com/ripplebiz/heltec-v4-map-support
There’s a section about how to copy to the LittleFS partition.
Thank you so much for this information!
I see the new expansion kit is coming out. Any info on if it will have a sd card slot or options to load a reasonable amount of map tiles?
