My name is Kristof Mulier. I’m part of a startup creating a new free IDE for microcontrollers: “Embeetle IDE”. Recently I purchased the following boards from Heltec:
WiFi LoRa 32 (V2), LoRa Band 433MHzWiFi Kit 32HT-M00 Dual Channel LoRa Gateway
I would like to add them to Embeetle IDE. However, to do that I’d need a sample project for each of them, such that our users can get started quickly. The sample project should be something very simple, such as a blinking LED.
The sample project should also comply with the following “rules”:
- It must be coded in C/C++ (and some assembly if needed).
- It must be self-contained (all source files present in the project folder).
- It must be makefile-based (build procedure is running gnu-make on a makefile).
I can’t find such sample projects for the Heltec boards. Can someone help me?
Thank you very much.
