I turn off vext before setting the state to LOWPOWER. But vext turns back on again while asleep or going to sleep. I know this because i have a GPS vcc connected to Vext. and the PPS led keeps flashing.
My sleep prep code:
void onSleep()
turnOffRGB();
Radio.Rx(0);
Radio.Sleep();
delay(3000);
uint32_t sleepTime;
volts = getBatteryVoltage();
while (second()>59){  // make sure seconds are not going to flip  over while calculating sleep time
int MyMinute=minute();
while(MyMinute>=WakeInterval){
MyMinute=MyMinute-WakeInterval;
sleepTime=(((WakeInterval)-MyMinute-1)60)+(61-second());
if (ValidTime==false){
sleepTime= map(constrain(volts,3600,4220),3600,4220,655,7);   // time sync lost so sleep for between 30 seconds  and 6 minutes
if (debug==true){
Serial.print("Not synced… ");
if (volts<LowVoltage){
sleepTime+=36008;    // sleep for  6  extra hours as low battery
      if (debug==true){
        Serial.print("VOLTS=");
        Serial.println((float)volts/1000);
        digitalClockDisplay();
        Serial.print("Time Awake ");
        Serial.print((unsigned long)(millis()-WakeMillis)/1000);
        Serial.println(" Seconds");
        Serial.print("Sleep for ");
        Serial.print (sleepTime);
        Serial.println(" seconds");
        Serial.println(millis());
        delay(100);
        Serial.flush();
        Serial.end();
       // iicSerial1.flush();
       // iicSerial1.end();
        Wire.end();
      VEXToff();
      digitalWrite(Vext,HIGH); // turn off power to the sensor
      CySysWdtDisable();
      TimerSetValue( &wakeUp, sleepTime*1000 );
      TimerStart( &wakeUp );
      //CySysPmDeepSleep;
      state=LOWPOWER;
my machine state loop:
  if (millis()-WDTmillis>(60*30*1000)){ // if not gone to sleep for 30 minutes
    HW_Reset(0);     //failed to power down so reboot
  switch(state)
    case TX:
      TXPacket();
    case RX:
    RXhandle();
    case WAIT_TX_DONE:
    case CHECK_BACK:
      state=RX;
    case LOWPOWER:
      SleepMillis=millis();
      LoRaWAN.sleep();
      //lowPowerHandler();
  if (state!=LOWPOWER){
      Radio.IrqProcess( );
