Hi everyone!
I’m trying to send messages from a MQTT broker to my LoRaWAN node. The problem is that sometimes I receive the message, but not always.
When I receive the message, in the ChirpStack Application Server you can see something like this:
And when the message doesn’t arrive to the node you can only see the ack message in ChirpStack Application Server.
In the Bridge Docker the next message also appears:
get device-queue item error object does not exist
And this one in the Network Server Docker:
level=error msg=“get device-queue item error” ctx_id=a782050a-6795-47d6-a705-e016c94cdde2 dev_eui=fe…fc error=“object does not exist”
Any idea of what is happening?
Thank you!
