I need to retrieve the time from the LoRaWAN gateway by sending the TimeReq message (as per LoRaWan specs, no payload msg).
is there a way to send such a message at MAC level to get the time from the gateway?
I’m using AB01 and AB02
thanks
thanks
Sorry, the lora gateway does not have this function.
You can try to get what you want in mqtt
mmm … my question is for the AB02 CubeCell software.
it is at MAC layer and I see it supported int he core library, but I do not see how to use it from the LoRaWan library level.
btw: my gateway does support this feature, it is a ChirpStackOS on raspberry.
thanks
hi,
we have updated the code: https://github.com/HelTecAutomation/ASR650x-Arduino/blob/master/libraries/LoRa/examples/LoRaWAN/LoRaWan_TimeReq/LoRaWan_TimeReq.ino
please git pull.
wow! thanks a lot Jason, I’ll test this week and report back.
hey Jason, looking at the code I can see how we do a TimeReq but it is not clear to me where we update the local clock. Who is going to process the TimeAns reply from the gateway??
also in your example how do we know if the request was successful?
again … tanks a lot for your help
LoRaMac.c
static void ProcessMacCommands** ( uint8_t *payload, uint8_t macIndex, uint8_t commandsSize, uint8_t snr, LoRaMacRxSlot_t rxSlot )
case SRV_MAC_DEVICE_TIME_ANS:
TimerTime_t currentTime = 0;
TimerSysTime_t sysTimeAns = { 0 };
TimerSysTime_t sysTime = { 0 };
TimerSysTime_t sysTimeCurrent = { 0 };
sysTimeAns.Seconds = ( uint32_t )payload[macIndex++];
sysTimeAns.Seconds |= ( uint32_t )payload[macIndex++] << 8;
sysTimeAns.Seconds |= ( uint32_t )payload[macIndex++] << 16;
sysTimeAns.Seconds |= ( uint32_t )payload[macIndex++] << 24;
sysTimeAns.SubSeconds = payload[macIndex++];
// Convert the fractional second received in ms
// round( pow( 0.5, 8.0 ) * 1000 ) = 3.90625
sysTimeAns.SubSeconds = sysTimeAns.SubSeconds * 3.90625;
// Add Unix to Gps epcoh offset. The system time is based on Unix time.
sysTimeAns.Seconds += UNIX_GPS_EPOCH_OFFSET;
// Compensate time difference between Tx Done time and now
sysTimeCurrent = TimerGetSysTime( );
sysTime = TimerAddSysTime( sysTimeCurrent, TimerSubSysTime( sysTimeAns, LastTxSysTime ) );
#ifdef LORAMAC_CLASSB_TESTCASE
DBG_PRINTF("receive SRV_MAC_DEVICE_TIME_ANS, set time=%u.%d\r\n", (unsigned int)sysTime.Seconds, sysTime.SubSeconds);
// Apply the new system time.
TimerSetSysTime( sysTime );
currentTime = TimerGetCurrentTime( );
LoRaMacClassBDeviceTimeAns( currentTime );
#ifdef CONFIG_LWAN
McpsIndication.DevTimeAnsReceived = true;
hi,
we have updated the code again. please git pull.
we add a function.When the time is updated, this function will be called(You can add what you want in this function). please refer the picture.
thanks a lot for your help. I can confirm that TimeReq works now using CubeCell AB02 and using a gateway (raspberry + i880a) with ChirpStackOS
I tried using this. I put some debug statements in LoRaMAC and it appeared that the TimeReq was going to be attached to the uplink, but the uplink never appeared in TTN and the TimeReq Answer was never processed in LoRaMAC. What prerequisites are necessary for the TimeReq to work?
mmm not sure how you access TTN but the time reply must come from the local gateway, not the remote server. I use ChirpStack and it works all the time…
my 2c
Hi Jason, there seems something wrong with the time request.
every time the “time request” is sent my modules get stuck in the join request. they just keep sending join request after the first uplink with time request MAC command is sent.
I’ve noticed this behavior on the cubecell module plus and also with the cubecell board plus
Is there a bug or it is just me doing something wrong?
