Hey
I am trying to build a Lorawan based weather station using a heltec wireless stick lite v3.
Transmitting the sensor values is no problem, but as soon as I try to put the ESP32 into deep sleep, it will not transmit data after waking up once. I do get “unconfirmed uplink sending … Deep sleeping for 10 seconds” in the serial monitor, but i does not transmit anything after deep sleep.
Please note I’m a beginner with LoRa stuff like this. I would really appreciate, if someone would look at my code:
#include “LoRaWan_APP.h”
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include “Adafruit_BME680.h”
/* OTAA para*/
uint8_t devEui[] = {};
uint8_t appEui[] = {};
uint8_t appKey[] = {};
/* ABP para*/
uint8_t nwkSKey[] = {};
uint8_t appSKey[] = {};
uint32_t devAddr = ( uint32_t );
Adafruit_BME680 bme;
#define TIME_TO_SLEEP 10 /* Duration ESP32 will go to sleep (seconds) /
uint32_t appTxDutyCycle = 10*1000;
#define LORA_SPREADING_FACTOR 12// [SF7…SF12]
/OTAA or ABP/
bool overTheAirActivation = false;
/ADR enable/
bool loraWanAdr = true;
bool isTxConfirmed = false;
/* Application port */
uint8_t appPort = 2;
- to the following table:
- Transmission nb | Data Rate
- 1 (first) | DR
- 2 | DR
- 3 | max(DR-1,0)
- 4 | max(DR-1,0)
- 5 | max(DR-2,0)
- 6 | max(DR-2,0)
- 7 | max(DR-3,0)
- 8 | max(DR-3,0)
uint8_t confirmedNbTrials = 10;
float temperature;
float humidity;
float pressure;
float gasResistance;
/* Read sensor data */
getBME680Readings();
/* Convert float values to integers for payload */
int int_temp = temperature * 100; // remove decimal point
int int_hum = humidity * 10; // remove decimal point
int int_pressure = pressure ;
int int_gas_resistance = gasResistance; // gas resistance is already an integer
/* Update appData with sensor data */
appDataSize = 8;
appData[0] = int_temp >> 8; // Store the high byte of int_temp in appData[0]
appData[1] = int_temp; // Store the low byte of int_temp in appData[1]
appData[2] = int_hum >> 8; // Store the high byte of int_hum in appData[2]
appData[3] = int_hum; // Store the low byte of int_hum in appData[3]
appData[4] = int_pressure >> 8; // Store the high byte of int_pressure in appData[4]
appData[5] = int_pressure; // Store the low byte of int_pressure in appData[5]
appData[6] = int_gas_resistance >> 8; // Store the high byte of int_gas in appData[6]
appData[7] = int_gas_resistance; // Store the low byte of int_gas in appData[7]
//if true, next uplink will add MOTE_MAC_DEVICE_TIME_REQ
Mcu.begin();
Serial.print(“setup”);
Wire.begin(46,45);
if (!bme.begin()) {
Serial.println(F(“Could not find a valid BME680 sensor, check wiring!”));
while (1);
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
resetLoRaWAN();
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
//Schedule next packet transmission
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass);
delay(3000);
goToSleep(TIME_TO_SLEEP);
void getBME680Readings(){
// Tell BME680 to begin measurement.
unsigned long endTime = bme.beginReading();
if (endTime == 0) {
Serial.println(F(“Failed to begin reading :(”));
return;
if (!bme.endReading()) {
Serial.println(F(“Failed to complete reading :(”));
return;
temperature = bme.temperature;
pressure = bme.pressure/100;
humidity = bme.humidity;
gasResistance = bme.gas_resistance / 1000.0;
void goToSleep(int sleepSeconds) {
Radio.Sleep( );
delay(100);
VextOFF();
// // Heltec V2 // Heltec V3
pinMode(17, INPUT); // 4 SDA // 17 OLED SDA
pinMode( 9,INPUT); // 5 LORA SCK // 9 LORA
pinMode(14,INPUT); // 14 RST 1278 // 12 LORA RST
pinMode(18, INPUT); // 15 SCL // 18 OLED SCL
pinMode(21,INPUT); // 16 OLED RST // 21 OLED RST
//pinMode(17,INPUT); // 17 HS1_DATA5 //
pinMode( 8,INPUT); // 18 LORA NSS // 8 LORA NSS
pinMode(11,INPUT); // 19 MISO // 11 LORA MISO
pinMode(12,INPUT); // 26 DIO026 // 12 DIO1 (LORA)
pinMode(10,INPUT); // 27 MOSI // 10 LORA MOSI
Serial.printf(“Deep sleeping for %d seconds\n”, sleepSeconds);
esp_sleep_enable_timer_wakeup(sleepSeconds * 1000000);
Serial.flush();
esp_deep_sleep_start();
Serial.println(“This will never be printed”);
void VextON(void)
pinMode(Vext,OUTPUT);
digitalWrite(Vext, LOW);
digitalWrite(Vext, HIGH);
void resetLoRaWAN() {
// Reset LoRaWAN parameters
if (overTheAirActivation) {
LoRaWAN.join();
// Other LoRaWAN configuration if needed
