Hello
I am building helium mapper that can be used in areas where there are no LoRa/Helium gateways.
I want to be able to power down the device and turn it on later and just send data, without the need to join the network (I have the uplink mode set to UNCONFIRMED and I use OTAA mode).
The device I use is CubeCell GPS-6502 ( HTCC-AB02S).
There is this parameter in Arduino config LORAWAN_Net_Reserve and in description in examples there is:
Do you have any example where this feature is used? I looked and cannot find anything about it.
When I set LORAWAN_Net_Reserve to ON nothing changes in behaviour of the device.
As a base/start I used the code from here:
I will be grateful for any help.
Regards,
Crey
