I have sent an email to support@heltec.cn but no response to get keys.
Can you please add ley to the database for the following serial numbers?
HeltecWifi LoRa32 v3 - 206680FA12F4
Thank you,
Maik
Thank you,
Maik
did you activate your serial number from heltec website. if you don’t follow the my method: short note space
Your method appears to be the same as the official instructions, neither of which will work if the module is not registered in the online database.
Or have I missed some new technique?
when I had licence problems with a Heltec LoRa V2 I gave up attempting to get any response from support@heltec.com
switched to using RadioLib
used File>Examples>RadioLib>LoRaWAN>LoRaWAN_Starter
which connected to The Things V3 LoRaWAN server without problem
Yeah, those RL devs are super clever & I hear they are really handsome too!
