Seems like I was misunderstanding something, lol. Not about this part specifically, but about if it was even necessary in the first place. I was always able to return a license after inputting an ID on their license lookup tool; however, I’m struggling in that my device does not accept it as a valid license. I assumed I had just skipped this step (referring to original post on forum), but now I believe the issue lies elsewhere. When using the license lookup tool and inputting any of the above ID’s it returns a different license than before I made this post/emailed heltec support, so, I know that they’ve seen this and done something.
My board does not seem to be responding to any sort of AT command through the serial monitor. If I put it into the code in my sketch the serial monitor will print as expected, however I think that’s just text and not indicative of any command truly being performed. I searched through the forums here for similar experiences and found a few other forum posts but all of them suggest to simply use the AT command and then there’s no follow-up. What am I missing here? Any help or pointers are surely appreciated.
Thanks.
