LoRaWAN gateway HT-02 can't setup region
Hi!
Yesterday, I installed a new Heltec MT-02 LoRaWAN gateway and configured it for TTN. I added it to my TTN console, but when a node sends join requests, I receive the following join-response downlink message. My region is AS923_1. I have successfully used AS923_1 as the region in other Heltec gateways on different LoRaWAN networks, connecting CubeCell GPS (HTCC-AB02S) nodes with the region parameter set to AS923 (AS1).
The configuration browser page for the HT-02 gateway doesn’t allow the selection of a specific LoRaWAN region when it is set for a basic station, LNS-type server. Does anyone know how to check its current region? I’m using the LoRaWanMinimal_APP library for a CubeCell GPS (HTCC-AB02S). How do I check its LoRaWAN version and parameters, such as dwell time, if there are no such variables in the LoRaWanMinimal_APP.h or LoRaWanMinimal_APP.cpp files? By the way, I already upgraded the HT-02 node firmware using this shell command rm -rf update_ && wget http://minerback.heltec.cn/download/update_basicstation.sh && chmod +x update_basicstation.sh && ./update_basicstation.sh* from Heltec online documentation.
Best regards.
“name”: “ns.down.join.schedule.fail”,
“time”: “2025-02-03T15:30:39.723788838Z”,
“identifiers”: [
“device_ids”: {
“device_id”: “b3a752772d16”,
“application_ids”: {
“application_id”: “4166fe6c-f6f2-40ce-8e87-ca2496077812”
“dev_eui”: “6081F943A2ABF909”,
“join_eui”: “6081F9EF856A87E0”
“data”: {
“@type”: “type.googleapis.com/ttn.lorawan.v3.ErrorDetails”,
“namespace”: “pkg/gatewayserver”,
“name”: “schedule”,
“message_format”: “schedule”,
“correlation_id”: “e59dd639886d4fa29ebd9f2cc66df1ba”,
“code”: 10,
“details”: [
“@type”: “type.googleapis.com/ttn.lorawan.v3.ScheduleDownlinkErrorDetails”,
“path_errors”: [
“name”: “schedule_path”,
“message_format”: "schedule on path {gateway_uid}",
“attributes”: {
“gateway_uid”: “787264fffee04f1e@ttn”
“correlation_id”: “146bd178bbb34895bcea650d91975d26”,
“cause”: {
“namespace”: “pkg/gatewayserver/io”,
“name”: “tx_schedule”,
“correlation_id”: “7e40df74ecbb4f8283e51967ea1a99e7”,
“code”: 10,
“details”: [
“path_errors”: [
“name”: “rx_window_schedule”,
“message_format”: “schedule in Rx window {window} failed”,
“attributes”: {
“window”: 1
“correlation_id”: “3be2e73e5ec64c769e743eab8b29c4db”,
“cause”: {
“namespace”: “pkg/gatewayserver/scheduling”,
“name”: “blocked”,
“message_format”: "sub band is blocked for {duration}",
“attributes”: {
“duration”: “4.56141s”
“correlation_id”: “f29cd8623e0e4a02801cd5ce600ab5e9”,
“code”: 8
“code”: 8
“attributes”: {
“window”: 2
“correlation_id”: “6dc953e999ac41b590f03e7df98d8f84”,
“cause”: {
“name”: “blocked”,
“attributes”: {
“duration”: “3.56141s”
“correlation_id”: “c3ffe5ce1a3245f181e6476eaefb62a8”,
“code”: 8
“code”: 8
“code”: 10,
“details”: [
“path_errors”: [
“attributes”: {
“window”: 1
“cause”: {
“name”: “blocked”,
“attributes”: {
“code”: 8
“code”: 8
“attributes”: {
“window”: 2
“cause”: {
“name”: “blocked”,
“attributes”: {
“code”: 8
“code”: 8
“correlation_ids”: [
“gs:uplink:01JK66YQ6ZZVY2DH39M74JHFRR”,
“ns:downlink:01JK66YRZ939A0QBYTFY6Q29EB”,
“ns:transmission:01JK66YRZ9YKAQS2MXAW043VT9”
“origin”: “ip-10-101-14-22.us-west-1.compute.internal”,
“context”: {
“tenant-id”: “CgN0dG4=”
“visibility”: {
“rights”: [
“RIGHT_APPLICATION_TRAFFIC_READ”
“unique_id”: “01JK66YRZBA8C386STMCTHD9XH”
On the TTN console.
Gateway -> General settings -> scroll down to LoRaWAN options -> click Expand.
Set it there.
When programming my LoRaWAN node, I noticed that only one region configuration parameter is available.
The TTN console offers more configuration parameters. I have tested multiple parameter combinations but haven’t succeeded yet.
How does this fix the issue with the HT-02?
Or is this something else?
The gateway channel plan and the device “region” aka channel plan need to be identical.
The problem remains. Both TTN region configurations (gateway and node) are identical.
The problem that you can’t setup the region for the HT-02? Or something new?
Does your device show uplinks in the gateway console on TTN?
The HT-02 status on the TTN console shows ‘connected’, but nodes cannot successfully join TTN through the HT-02. The TTN live data verbose shows this error after a ‘accept join request’ and ‘successfully processed join-request’ messages, as shown in the following screenshot:
…ns.down.join.schedule.fail… Path_errors": [
“attributes”: {
“window”: 1
“correlation_id”: “1a6ad278de31473dbf9350f7fa72b2ab”,
“cause”: {
“name”: “blocked”,
“attributes”: {
“duration”: “24.870962s”
