Dear All,
I have a problem with receiving data from sensor in Chirpstack (using Wireless stick V3 and Ebyte Gateway).
I do not see the uplink frames in Chirpstack LoRaWAN frames (I have last version Chirpstack 4). As it is new version, I can’t find Live Lorawan frames. I work first time with Wireless Stick V3 (wanted to send data from Humidity sensor to the EBYTE gateway). I have already added the Ebyte gateway to Chirpstack.
There is my code in Arduino IDE:
`#include “LoRaWan_APP.h”
#define SENSOR_PIN 1 // Define the pin where the capacitive soil moisture sensor is connected (analog pin)
// LoRaWAN parameters
uint8_t devEui[] = { 0x5B, 0x48, 0xED, 0x53, 0xA5, 0x5B, 0xE2, 0x6F };
uint8_t appEui[] = { 0x2F, 0x01, 0xFE, 0x2C, 0xD7, 0x0D, 0x17, 0x46 };
uint8_t appKey[] = { 0x16, 0x07, 0x16, 0x42, 0xFF, 0xB8, 0x6A, 0x3D, 0x3D, 0x7C, 0xA0, 0x0B, 0x1D, 0xA6, 0x6D, 0xF4 };
/* ABP para*/
// LoRaWAN channel mask - Customize based on your region if needed
uint16_t userChannelsMask[6] = { 0x00FF, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000 }; // This enables channels 0-7
// Number of trials for confirmed messages
uint8_t confirmedNbTrials = 4; // Set to how many times the device should retry sending a confirmed message
bool loraWanAdr = true;
bool isTxConfirmed = true;
uint8_t appPort = 2;
// Prepare and send uplink payload
void setup(void) {
Serial.begin(9600);
Mcu.begin(HELTEC_BOARD, SLOW_CLK_TPYE); // Initialize Heltec LoRaWAN
LoRaWAN.setDefaultDR(3);
void prepareTxFrame(uint8_t port) {
int sensorValue = analogRead(SENSOR_PIN); // Read sensor value
// Convert sensor value to the format you want to send (e.g., percentage)
float moisturePercentage = map(sensorValue, 0, 4095, 0, 100);
int moistureInt = (int)(moisturePercentage); // Convert to integer
Serial.print("Soil Moisture Raw Value: ");
Serial.println(sensorValue);
Serial.print(“Soil Moisture Percentage: “);
Serial.print(moisturePercentage);
Serial.println(” %”);
// Load the data into the payload
appData[0] = (moistureInt >> 8) & 0xFF; // High byte
appData[1] = moistureInt & 0xFF; // Low byte
// Set payload size (2 bytes in this case)
appDataSize = 2;
void loop(void) {
// Device state logic
switch (deviceState) {
case DEVICE_STATE_JOIN:
LoRaWAN.join(); // Join the network
case DEVICE_STATE_SEND:
prepareTxFrame(appPort); // Prepare the sensor data
LoRaWAN.send(); // Send the data to the network
case DEVICE_STATE_CYCLE:
// Wait for the next transmission cycle
txDutyCycleTime = appTxDutyCycle + randr(-APP_TX_DUTYCYCLE_RND, APP_TX_DUTYCYCLE_RND);
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass);
delay(2000); // Delay between transmissions
