It’s great having access to a device that can run the official Semtech code - well done!
I have two things I need to do:
Wake up every minute to check sensors are in range (ie no alarm)
Send a packet out of schedule if there is a sensor alarm.
I think I need to create a new timer because I think the device wakes up when a timer expires but that bit of code is in the assembly so I can’t be sure and my code tests have got confusing.
I totally failed yesterday to find a way to send on demand - I tried the device state and other things as well.
I did manage to programmatically change the data rate for one transmission, but then it appears to reset itself back to the setting in the defines.
Does anyone have sample code for a timer task for sensor readings and for triggering a send please.
Cheers,
Nick
PS, looking forward to getting my CubeCell Dev boards to try them out!
