Hello Guys, hope all is well. This is my first post.
I have a ‘HELTEC 915 ESP32 LoRa OLED Board V3 Type-C SX1262 + 915MHz LoRa Antenna U.FL IPEX to SMA for Arduino IOT LoraWan Gateway, not Compatible with LoRa 32 V2’.
I am trying to run the sketch that is under ‘Demo 1 – Simple Data Transfer’ ( https://dronebotworkshop.com/lora/ )
I exactly copied this sketch on both my boards and uploaded them via my Arduin IDE. It compiled fine.
The probelm is that the Serial monitor on the Arduino IDE keeps telling me that there is an issue.
The Sender’s serial monitor says:
(����u#��!�LoRa Sender Test
Starting LoRa failed!
The receiver’s serial monitor says:
(��L��DJ�LoRa Receiver Test
Those jumbled characters in both serial outputs sometimes mean that there is a Serial communcaiton issue. But, I have checked the baud rates on the sketch and the serial monitor and they are the same.
I feel that my csPin, resetPin, irqPin are not the correct pon numbers.
This is what they say on the sketch: ( The sketch is at the end below )
const int csPin = 4; // LoRa radio chip select
const int resetPin = 2; // LoRa radio reset
const int irqPin = 3; // Must be a hardware interrupt pin
I looked all over the internet and also referred to the schematic below that is provided by Heltec.
I changed my pins to:
const int csPin = 8; // LoRa radio chip select
const int resetPin = 12; // LoRa radio reset
const int irqPin = 14; // Must be a hardware interrupt pin
The problem still persists even after changing the pin numbers.
I was wondering if someone could give me some feedback.
Thank you for your reply!
#include <SPI.h>
#include <LoRa.h>
Serial.begin(9600);
while (!Serial);
LoRa.setPins(csPin, resetPin, irqPin);
Serial.println(“LoRa Receiver Test”);
if (!LoRa.begin(915E6)) {
Serial.println(“Starting LoRa failed!”);
while (1);
int packetSize = LoRa.parsePacket();
if (packetSize) {
Serial.print(“Received '”);
while (LoRa.available()) {
Serial.print((char)LoRa.read());
Serial.print("’ with RSSI ");
Serial.println(LoRa.packetRssi());
