I followed the thread here: WiFi LoRa 32 Deep Sleep, LoRa radio leaves continuous recieve mode (assuming)
And I tried the code at the bottom and also added manual library definitions for LoRa.h and SPI.h, but it doesn’t seem to wake up as per the thread author. I also tried modifying LoRaSender and LoRaReceiver examples that do not use the heltec.h library (as this isn’t updated for the v3 devices) but they never wake up after receiving a LoRa packet either.
I compared the WiFi LoRa 32 v2 pinout with the v3 and it seems like pin26 and pin14 still are connected to the same SX pins, so I think the code should work. Has anyone gotten something like this to work with the v3 boards?
