Hello, I already saw the other thread that have the same problem as I, since there is no solution I’m opening a new one.
I have a Lora Node 151 and I’m trying to configure it, I plugged an USB cable that I was using before to run tests in other Lora Devices and it worked out fine. But for installing the Lora Node firmware doesn’t work at all:
10:32:55 : Error: unknown or unsupported device (DevID = 0x0000)
10:54:48 : USB speed : Full Speed (12MBit/s)
10:54:48 : Manuf. ID : STMicroelectronics
10:54:48 : Product ID : STM32 BOOTLOADER
10:54:48 : SN : 74E7A1316BA0
10:54:48 : FW version : 0x011a
10:54:48 : Device ID : unknown
I don’t know what else I can do, already plugged with the USER button pressed, it detecs the USB port, this error occurs when I try to make a connection. What can I do?
