Hi everyone!
I am new to Lora and Lorawan, so still have a lot to learn, but I could not find a solution to a strange problem: If I download the basic hardware test code to two pieces of Heltec lora node 151 (one sender and one receiver/sender) they work well, they could communicate 700-800 meters away from each other (or maybe more, but this was my test distance).
But when I tested this node with TTN (dowloaded the lorawan example code and set everything for TTN as described) I could send data to the network (it appeared in TTN) but the RSSI is extremely poor, it was -110 when 5 meters away from the gateway (I tested it with other 151 node as well). The gateway is working well, so I guess it is a software issue. Or is it possible that the Lora Node 151 is simply not compatible with my gateway?
