Lora Esp32 ping pong example stuck in rx mode
when using the ping pong example and adjusting the frequency and removing the 1 second delay, both of the boards get stuck in rx mode within a minute. Please help me.
Heres my code btw/* Heltec Automation Ping Pong communication test example
  • Function:
  • Description:
    1. Only hardware layer communicate, no LoRaWAN protocol support;
    1. Download the same code into two devices, then they will begin Ping Pong test each other;
    1. This example is for CubeCell hardware basic test.
  • HelTec AutoMation, Chengdu, China
  • �ɶ��������Զ����Ƽ����޹�˾
  • www.heltec.org
#include “LoRaWan_APP.h”
#include “Arduino.h”
#define RF_FREQUENCY 433000000 // Hz
#define TX_OUTPUT_POWER 5 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
void OnTxDone( void );
void OnTxTimeout( void );
typedef enum
LOWPOWER,
STATE_RX,
STATE_TX
}States_t;
int16_t txNumber;
States_t state;
bool sleepMode = false;
int16_t Rssi,rxSize;
Mcu.begin();
txNumber=0;
Rssi=0;
Radio.Init( &RadioEvents );
state=STATE_TX;
switch(state)
case STATE_TX:
  txNumber++;
  sprintf(txpacket,"hello %d, Rssi : %d",txNumber,Rssi);
  Radio.Send( (uint8_t *)txpacket, strlen(txpacket) );
  state=LOWPOWER;
case STATE_RX:
  Radio.Rx( 0 );
  state=LOWPOWER;
case LOWPOWER:
  Radio.IrqProcess( );
Serial.print(“TX done…”);
state=STATE_RX;
Radio.Sleep( );
Serial.print(“TX Timeout…”);
state=STATE_TX;
Rssi=rssi;
rxSize=size;
rxpacket[size]=’\0’;
Radio.Sleep( );
Serial.printf("\r\nreceived packet \"%s\" with Rssi %d , length %d\r\n",rxpacket,Rssi,rxSize);
Serial.println("wait to send next packet");
state=STATE_TX;
Im using Heltec LoRa esp32 v2 on 433 frequency. I was thinking of making one board only have a tx timeout and one only have a rx timeout to prevent this. But i dont know much and cant find anything about an rx timeout.
edit: i have no idea why the code did that.
