Because at my order time there was no V2 board available I ordered V3 boards for my sensor network. I can not make the intercommunication between the two boards (V2 and V3). With v3 I adapted my software from the old Lora library to the new RadioLib.
Parameters for the old Lora V2:
Heltec.begin(true /DisplayEnable Enable/, true /LoRa Enable/, true /Serial Enable/, true /LoRa use PABOOST/, 868 /LoRa RF working band/);
for V3:
                             LORA_CRC, 0, 0, LORA_IQ_INVERSION_ON, 3000 );
                             0, LORA_CRC, 0, 0, LORA_IQ_INVERSION_ON, true );
with:
#define LORA_BANDWIDTH                              0         // [0: 125 kHz,
#define LORA_SPREADING_FACTOR                       10         // [SF7…SF12]
#define LORA_CODINGRATE                             1         // [1: 4/5,
#define LORA_PREAMBLE_LENGTH                       8 // 8         // Same for Tx and Rx
#define LORA_CRC                                    true
#define LORA_SYNC_WORD                              0x34
Is there any hope for a communication or should I buy the v2 board again?
Why does the Lora V3 chip has a 16-Bit Sync word but the Api provides only a 8 bit parameter?
Which parameter for sync word is correct for function Radio.SetSyncWord(byte sncword); to have communication with V2 with sync word 0x34?
Thank you!
