Hi All,
My first post on here.
I am currently building a project where I will use 60 VL53L1X sensors and need a neat solution to house them, I came across the Capsule and wondered how transparent the caps are at the sensor side? The units will be outside and in a semi harsh environment 30°C, tropical weather.
I have my test setup with esp8266 D1 mini which work very well but my issue is using the VL53L1X outside, I am also looking at making the switch to LoRa due to a very congested WIFI network.
My ideal setup would be adding the Heltec LoRa gateway to my existing raspberry pi that is already running Mosquitto.
Thanks in advance
D
, my output from Arduino either shows 0 more than 3 meters and 1 less than 3 meters and Node red converts to empty or full to a topic.
