License problem on WiFi LoRa 32(V3)
Hi guys. I’m pretty new to all this, so sorry if I make any mistake in my documentation of the problem:
I’m required to connect to the TTN LoRaWan using my LoRa 32(V3) to upload some data. The board version is 3.0.0 and the library version is 2.0.2.
I’m using Examples-> Heltec ESP32 Dev-Boards ->LoRaWAN -> LoRaWan code to test it out. But I keep on getting this error at the serial:
http://www.heltec.cn/search/
ESP32ChipID=D0256A33E864
The link is not accessible. So I don’t know what information it has. I’ve checked the devui appui and appkey thorughly. And it wouldn’t seem to be an error regarding this anyway. I can check the nearest gateway for uplinks from end devices on my dashboard, but don’t see any join requests there either.
I did find one prior topic on this, but couldn’t understand much from it. Any help and advice would be greatly appreciated! Looking forward to your replies.
I hope This document can help you solve this problem
Hi! A ChipID license is not provided on the specified site, and support does not respond to an email request. How do I get this license? My chip’s data :
ESP32 Chip model = ESP32-D0WDQ6 Rev 101
This chip has 2 cores
ESP32ChipID=38926F1815AC
board type: HTIT-WB32LA
hi, any success ? i erased my falsh and now need to generate license number too.
edit: https://resource.heltec.cn/search works like it should, just enter your chip ID there and get license, then remove 0x and , from license number issue a command by COM: AT+CDKEY=License
