I just received a CubeCell and was running sketch Factory_Test_AB01
At no time does the LED lite at all! My question is there a simple sketch to test the LED to see if something is wrong with my board?
Thanks Chris
Thanks Chris
Just set RGB Led option to on in the board settings
That’s not it I tried a new board and it works with the same sketch but not the first one!
I will send back the one not working.
I have another question for someone if I include both
#include “LoRaWan_APP.h”
#include “CubeCell_NeoPixel.h”
I get a compiling error: C:\Users\MADHAT~1\AppData\Local\Temp\arduino_build_302786\libraries\LoRa\LoRaWan_APP.cpp.o:(.bss+0x18): multiple definition ofpixels’
C:\Users\chris~1\AppData\Local\Temp\arduino_build_302786\sketch\Trk.ino.cpp.o:(.bss+0x0): first defined here
collect2.exe: error: ld returned 1 exit status`
> Blockquote
Any ideas as to how to fix this? If I remove one or the other I have no errors
Thanks Chris
Never Mind I got it to work I don’t know what I was thinking!!!
Thanks Anyway
