After the helium issues this week, one of my Heltech units is having some issues.
latest firmware:get failed
latest block height: get failed
how do we get this resolved?
thanks
thanks
Have the same issue, can support team pick this quickly please.
The latest firmware is obtained from the heltec server, and the latest block height is obtained from the helium API (https://api.helium.io/v1/blocks/height),
The failure to obtain the latest firmware may be due to the network. The latest block height can be viewed directly from https://api.helium.io/v1/blocks/height.
My main issue is that the Miner has no miner image. Do you know where i can download a image, i ahve tried exporting from another hotspot and uploading but the image fails to launch after upload check is Ok
Adrian
