Is my MeshPocket Qi2 dead? (no bluetooth, no UDF)
I was trying to update my device via the ble c android meshtastic app. The MeshPocket froze, turned off bluetooth and now I can’t connect to it, the UDF also won’t turn on. The screen froze.
I connected the magnetic cable, but windows does not detect the MeshPocket.
I did “Double-click the USER button → enter DFU mode.” but it doesn’t work, windows doesn’t see any USB devices.
As a powerbank, it continues to work and flashes green when the power button is pressed.
How I can return to life MeshPocket ?
sometimes connecting the magnetic connector, but doing this faster with connect disconnect and connect again is like a “REAL” double reset. Then it should appear to be flashed
