Totally weird issue with programming the wireless shell seems to have appeared.
I have set up a unit with s single sensor and used a 30second deep sleep cycle. Now when i try and reprogram the wireless shell it seems to be quite intermitend. After about 15 or so attempts it will reprogam if im lucky. There seems to be no real logic to this at all.
It works sometimes and other times it just keeps failing.
