Dear Heltec Automation Community,
I am currently evaluating the integration of your HT-HC32 (ESP32 Wi-Fi HaLow module) with a DWM1001 module based on the nRF52832 MCU for my application.
I have reviewed the interface options on both modules, and while the DWM1001 documentation provides clarity on its SPI interface, I am unclear about the SPI interface on the HT-HC32 side. Specifically, I would like to know:
- Is it possible to establish SPI communication between the HT-HC32 and the DWM1001?
- Which SPI interface/pins on the HT-HC32 should be connected to the SPI pins of the DWM1001?
- Can the HT-HC32 act as a host (master) device in this SPI setup?
- Is the HT-HC32 capable of interfacing with and hosting a peripheral MCU like the nRF52832?
- Are there any specific steps or configurations required to enable SPI communication between the two modules?
I would highly appreciate any documentation, pin mapping, or guidance you could provide regarding this setup.
Looking forward to your support.
Best regards,
Vinith
