Hi  , I try in a simple code  to  turn on / off  a color of the RGB onboard led ,   when  i include the “LoRaWan_APP.h”  the led  go crazy  an change of color  .
I disable the option in arduino "TOOLS =>LORAWAN_RGB = DISABLE
code:
#include “LoRaWan_APP.h”   //    when I comment  this line ,  the led work fine
#include “CubeCell_NeoPixel.h”
CubeCell_NeoPixel pixels(1, RGB, NEO_GRB + NEO_KHZ400);
pinMode(Vext,OUTPUT);
digitalWrite(Vext,LOW); //SET POWER
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
pixels.clear(); // Set all pixel colors to ‘off’
pixels.setPixelColor(0, pixels.Color(0, 0, 100));
pixels.show();   // Send the updated pixel colors to the hardware.
delay(100); // Pause before next pass through loop
delay(1000); // Pause before next pass through loop
any suggestion to use  the led with this library ??
thanks
