I have two devices Wifi Lora V2 and HTCC-AB02A with the same issue of joining.
I try to join to the Objenious network (https://objenious.com/) French operator EU868.
I have the message repeatly “JOINING” … .
When I try on TTN network with exactly the same program it works perfectly (of course I remove registration from TTN before to test on Objenious).
Any help will be appreciate
The configuration I have for my Wifi Lora V2:
build_flags =
-D REGION_EU868
-D ACTIVE_REGION=LORAMAC_REGION_EU868
-D LoRaWAN_DEBUG_LEVEL=0
I use the default program OTAA_OLED:
- HelTec Automation™ LoRaWAN 1.0.2 OTAA example use OTAA, CLASS A
- Function summary:
- use internal RTC(150KHz);
- Include stop mode and deep sleep mode;
- 15S data send cycle;
- Informations output via serial(115200);
- Only ESP32 + LoRa series boards can use this library, need a license
- to make the code run(check you license here: http://www.heltec.cn/search );
- You can change some definition in “Commissioning.h” and “LoRaMac-definitions.h”
- HelTec AutoMation, Chengdu, China.
- 成都惠利特自动化科技有限公司
- https://heltec.org
- support@heltec.cn
*this project also release in GitHub:
*https://github.com/HelTecAutomation/ESP32_LoRaWAN
#include <ESP32_LoRaWAN.h>
#include “Arduino.h”
/*license for Heltec ESP32 LoRaWan, quary your ChipID relevant license: http://resource.heltec.cn/search */
uint32_t license[4] = {0x0E506D33, 0xED763A11, 0x269C6784, 0x4D213E5C};
/* OTAA para*/
uint8_t DevEui[] = { VALUES }; // pour OTAA connexion
uint8_t AppEui[] = { VALUES };
uint8_t AppKey[] = { VALUES };
/* ABP para*/
uint8_t NwkSKey[] = { [VALUES };
uint8_t AppSKey[] = { [VALUES] };
uint32_t DevAddr = ( uint32_t )0x007e6ae1;
/OTAA or ABP/
/ADR enable/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
- to the following table:
- Transmission nb | Data Rate
- 1 (first) | DR
- 2 | DR
- 3 | max(DR-1,0)
- 4 | max(DR-1,0)
- 5 | max(DR-2,0)
- 6 | max(DR-2,0)
- 7 | max(DR-3,0)
- 8 | max(DR-3,0)
/*LoraWan debug level, select in arduino IDE tools.
- None : print basic info.
- Freq : print Tx and Rx freq, DR info.
- Freq && DIO : print Tx and Rx freq, DR, DIO0 interrupt and DIO1 interrupt info.
- Freq && DIO && PW: print Tx and Rx freq, DR, DIO0 interrupt, DIO1 interrupt, MCU sleep and MCU wake info.
appDataSize = 4;//AppDataSize max value is 64
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
void setup()
if(mcuStarted==0)
LoRaWAN.displayMcuInit();
while (!Serial);
SPI.begin(SCK,MISO,MOSI,SS);
Mcu.init(SS,RST_LoRa,DIO0,DIO1,license);
switch( deviceState )
case DEVICE_STATE_INIT:
case DEVICE_STATE_JOIN:
LoRaWAN.displayJoining();
LoRaWAN.join();
case DEVICE_STATE_SEND:
LoRaWAN.displaySending();
prepareTxFrame( appPort );
LoRaWAN.send(loraWanClass);
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.displayAck();
LoRaWAN.sleep(loraWanClass,debugLevel);
