How long can the twisted pair cable be on the I2C Bus from BME280 Board to the Heltec Lora32 V3
I2C Lora-32 to BME280 How long wires
This is widely debated across the internet and twisted pair has a subtle, erm, twist to it.
Short answer, 20cm is about the best you can do.
If you have twisted pair of a Gnd around each of the signals and a separate twisted pair for V+, you may be able to do a few meters. YMMV, a lot.
You may have to review the values of your pull-up resistors to suit depending on the cable. Again, numerous articles on the interwebs on this.
But overall, you’re traveling through another dimension – a dimension not only of sight and sound but of mind. A journey into a wondrous land whose boundaries are that of imagination. That’s a signpost up ahead: your next stop: Electronic Engineering Zone!
