HW-Timer interrupt on CubeCell AB01?
Dear Foristers,
can anyone, please, send me an excample for a HW-Timer interrupt.
This is my Demo, which I used successfully on a ESP32 D1 Mini NodeMCU, but I cannot compile it for CubeCell AB01:
 *  Demo 22: How to use Timer interrupt in Arduino ESP32
 *  File:    Timer0_ISR.ino
 *  Date:    2022/02/11
 *  Version: v1.0
 *  Author:  based on code from Tech It Yourself
 *           http://www.iotsharing.com/2017/06/how-to-use-interrupt-timer-in-arduino-esp32.html
 *  Update:  2022/02/11 - Äd Franzis
 *  Tested on this environment:
 *  Board:            "WEMOS D1 MINI ESP32"
 *  Upload Speed:     "921600"
 *  CPU Frequency:    "240MHz (WiFi/BT)"
 *  Flash Frequency:  "80MHz"
 *  Partition Scheme: "Standard"
 *  Chip is ESP32-D0WDQ6 (revision 1)
 *  Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
 *  Crystal is 40MHz
/* create a hardware timer0 */
hw_timer_t * timer0 = NULL;
/* LED pin */
#define GPIO_LED LED_BUILTIN
/* LED state */
volatile byte state = LOW;
void IRAM_ATTR onTimer0(){
  state = !state;
  digitalWrite(GPIO_LED, state);
}// END OF: IRAM_ATTR onTimer0()
  pinMode(GPIO_LED, OUTPUT);
  /* Use 1st timer of 4 */
  /* 1 tick take 1/(80MHZ/80) = 1us so we set divider 80 and count up */
  timer0 = timerBegin(0, 80, true);
  /* Attach onTimer0 function to our timer0 */
  timerAttachInterrupt(timer0, &onTimer0, true);
  /* Set alarm to call onTimer0 function every second 1 tick is 1us
  => 1 second is 1000000us */
  /* Repeat the alarm (third parameter) */
  timerAlarmWrite(timer0, 1000000, true); //timer ISR onTime0 will be called each second
  /* Start an alarm */
  timerAlarmEnable(timer0);
  Serial.println("timer0 is started");
}// END OF: setup()
  /* empty loop */
}// END OF: loop()
In the finel code, loop() is not empty, i.e. CubeCell will not sleep and will not be in LowPower-Mode.
Unfortunately, I couldn’t find any information about the HW-Times on CubeCell.
I hope, someone can help me.
Kind regards
Äd
