HTTC AB02 conexión a ttn
Buenos días,
este es mi primer post, espero que puedan ayudarme
Como puedo programar mi placa para poder conectar a TTN? he podido conectar el gateway y me falta este dispositivo.
Muchas gracias!
hi,
please refer the links:
  1. for HT-M00:https://heltec-automation-docs.readthedocs.io/en/latest/gateway/ht-m00/connect_to_server.html
  2. for HT-M02: https://heltec-automation.readthedocs.io/zh_CN/latest/gateway/ht-m02_4g/connect_to_server.html#ttn
Good afternoon, thank you very much for the information, I managed to connect my Gateway HT-M01 to TTN, but I have a problem, it connects only one second and disconnects for 30 seconds and reconnects, it becomes cyclical.
I am using the PicoGW tool on windows, how can I confuse my gateway so that I can connect a TTN permanently?
Thanks a lot !
HT-M01 needs to be connected to PC(Use HT-M01 with Windows).
you can use the Raspberry: https://heltec-automation-docs.readthedocs.io/en/latest/gateway/ht-m01/qucik_start.html#use-ht-m01-with-linux-raspberry-pi
