Hi team,
The AB02S board has a GPS on it, the Air530.
Question from another thread: The Air530 says it supports GPS/GLONASS/Beidou/Galileo/QZSS/SBAS, at least in some places on the internet. Specs say only GPS and Beidou?
It also appears to have a PCB antenna of some kind on the upper left on the GPS side. Is this a GPS antenna (it’s pretty small, hence my doubt)?
2a. If I use the external GPS antenna, is there something to remove/switch to disable the internal one?
Antenna connectors for LoRa and for GPS are on each side of the board, back to back?
Deep Sleep power consumption on the main page is 50ua (I assume due to the GPS?). The specs page says 3.5uA, so that needs updating.
Great board, looking forward to getting them.
Regards,
Bruce
