Hi out there, im just starting to use AB02S GPS Module.
If GPS is working an small green LED beside the USB port ist flashing, not the RGB LED!
I want to stop this LED flashing, but i can’t find anything about this in the code.
On shematic I think it is LED D6 on IO8 / GPIO8, but on th Pinout Diagram there is on GPIO8 only SCL1.
But on GPIO12 there is GPS_LED, only going to header P2.
Need here some clarification and where to turn this LED off.
