HTCC-AB02s Executing two programs but only one is being downloaded
Hi @jasonXu, @Supporter
I have noticed that if I download a sketch into my HTCC-AB02S , the device is executing the previous sketch which has been downloaded. is that possible? I have replaced the micro SD thinking that it was the problem but when i format the sd and i ran a sketch, i saw that on the SD which was previously empty. I had two .TXT documents which to me it sounds like the cubecell board is broken or not working properly.
Any ideas?
Thanks for your help.
Regards,
Sorry, i think it is impossible.
Could you show your serial print log?
Hi @jasonXu,
What I mean is that if I download a sketch which only creates a .TXT for example BMP180 and a previously download a sketch which only creates a .TXT for example a BME280. Even when having the SD empty before i connect to the cubecell (HTCC-AB02s) . The download of a sketch means that somehow the board is executing the actual and the previous sketch. I know it sounds crazy but it’s happening. i will try with another board which i order from my local shop.
Thanks for your help and i will update you with more info.
Regards
