Hi Folks.
I am desperately trying to get the UV sensor VEML6075 running via I²C on the HTCC-AB02S. However without success.
I have already tried the following things:
Sensor tested on an ESP8266 --> i.o.! Sensor is recognized by an I²C scanner and can be read out.
Sensor connected to I²C 1 (default) or 2 (with wire1.begin etc.) of the HTCC-AB02S --> is not recognized by the I²C scanner. No data can be read out.
Tested different versions of the CubeCell framework (1.2.0 … 1.5.0) --> no success
Other sensors (e.g. BME280) are recognized by the I²C scanner on the HTC-AB02S. At the I²C interface 1 or also at the I²C interface 2.
It can’t be caused by pull-up resistors either. I have already measured this. Also not at the 3V3 power supply. This also fits.
What else can I try in your opinion? I’m afraid it’s the wire library of CubeCell…
Many greetings
Martin
