Hi, is there a comparison of the HTCC-AB02A and LoRa Node 151’s specs? Here’s what I see so far as the similarities & differences. Also, which compiler is recommended for the Node 151?
SIMILARITIES: Same size.
DIFFERENCES: HTCC-AB02A: FCC certified (and CE), Arduino compatible, almost no documentation available for the uC, Low power consumption
LoRa Node 151: not FCC certified (only CE), ST Micro uC , not Arduino compatible, RAM and other specs clearly available, even lower power consumption, a bit more more expensive.
