HTCC-AB02A LoRa deep sleep
I am using the HTCC-AB02A to send LoRa data. Then I put the board into deep sleep.
After the command ‘Radio.Sleep( );’ I have to pause for 3 seconds, otherwise the command ‘lowPowerHandler();’ will not work and the board will not go into deep sleep.
Is there any way around the problem?
code:
/* Heltec Automation send communication test example
 * Function:
 * 1. Send data from a CubeCell device over hardware
 * this project also realess in GitHub:
 * https://github.com/HelTecAutomation/ASR650x-Arduino
#include "LoRaWan_APP.h"
#include "Arduino.h"
 * set LoraWan_RGB to 1,the RGB active in loraWan
 * RGB red means sending;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
#define RF_FREQUENCY                                868000000 // Hz
#define TX_OUTPUT_POWER                             14        // dBm
#define LORA_BANDWIDTH                              0         // [0: 125 kHz,
                                                              //  1: 250 kHz,
                                                              //  2: 500 kHz,
                                                              //  3: Reserved]
#define LORA_SPREADING_FACTOR                       7         // [SF7..SF12]
#define LORA_CODINGRATE                             1         // [1: 4/5,
                                                              //  2: 4/6,
                                                              //  3: 4/7,
                                                              //  4: 4/8]
#define LORA_PREAMBLE_LENGTH                        8         // Same for Tx and Rx
#define RX_TIMEOUT_VALUE                            1000
#define BUFFER_SIZE                                 30 // Define the payload size here
#define SLEEP_TIME 3600000 // 1 hour
static TimerEvent_t DeepSleep;
char txPacket[BUFFER_SIZE];
  // Serial monitor at 115200 baud
  // Pin
  pinMode(Vext,OUTPUT);
  // init LoRa module
  Radio.Init( &RadioEvents );
  Radio.SetSyncWord(0x12);
  // Battery
  uint16_t voltage = getBatteryVoltage();
  sprintf(txPacket,"%s","/Zisterne/Batterie=");
	sprintf(txPacket+strlen(txPacket),"%d",voltage);
  Serial.printf("\rsending packet \"%s\" , length %d\r\n",txPacket, strlen(txPacket));
  Radio.Send( (uint8_t *)txPacket, strlen(txPacket) ); // send the package out
  // Sensor
  digitalWrite(Vext, LOW); // sensor power on
  delay(100);
  uint16_t level=analogRead(ADC2);
  digitalWrite(Vext, HIGH);  // sensor power off
  sprintf(txPacket,"%s","/Zisterne/Level=");
  sprintf(txPacket+strlen(txPacket),"%d",level);
  Radio.Sleep( ); // aktivate sleep for LORA
  // go back to deep sleep mode
  TimerSetValue( &DeepSleep, SLEEP_TIME );
  TimerStart( &DeepSleep );
  delay(3000); //???????
  lowPowerHandler();
