I have recently acquired 2 x HTCC-AB02.
I have installed according to https://heltec-automation-docs.readthedocs.io/en/latest/cubecell/quick_start.html all the required files and library’s.
I can see in the Device manger (Using Windows 10) that comport 23 is active with both boards when I connect them.
The IDE don’t recognize them.
I have used both methods to put them in boot loader.
- CubeCell not connect to a computer – Press the “USER” button of the CubeCell while plugging it to any USB port of a computer.
- CubeCell already connected to a computer – Keep the “USER” button pressed → Press the “RESET” button → Release the “RESET” button → release the “USER” button.
I have changed the USB cable out 3 times.
Tested the USB cable with other Arduino based boards ant they work with them.
Any ideas will be appreciated as to how to connect to these boards.
