HTCC-AB02 Receiver dies after a few hours
I’ve got a few HTCC-AB02 boards. The one I use for transmitting works as intended, sending sensor status about 30 times per minute, around 50 bytes at a time. But I’m struggling to write stable code for the boards I use for receiving. I’m trying to use one board as a bridge that listens to the LoRa signals and writes everything to the serial connection. A Linux box then stores the messages.
What I currently have is based on the examples (https://github.com/HelTecAutomation/CubeCell-Arduino/blob/master/libraries/LoRa/examples/LoRaBasic/LoRaReceiver/LoRaReceiver.ino). I’ve only changed the frequency to 433 MHz and BUFFER_SIZE to 60 bytes and set the LED to alternate its color, to be able to see whether the board still works. The problem is that the receiver hangs after a random time, usually after less than 8 hours. I have no idea what part of the code hangs, but after hanging, the led stops alternating its color and nothing is printed to the serial connection anymore.
I’ve tried multiple HTCC-AB02 boards. They hang regardless of whether they are connected to my Linux server or directly to a power supply. In all cases, I’m using USB to power the devices. The boards are new and I haven’t soldered anything to them.
Where could the problem be? Am I missing something obvious? Is the problem related to interrupt handling? I’m sure someone successfully uses a HTCC-AB02 to receive signals and forward them to a computer via serial connection. Or should I try something different?
Here’s my code:
/* Heltec Automation Receive communication test example
* Function:
* 1. Receive the same frequency band lora signal program
* this project also realess in GitHub:
* https://github.com/HelTecAutomation/ASR650x-Arduino
#include "LoRaWan_APP.h"
#include "Arduino.h"
* set LoraWan_RGB to 1,the RGB active in loraWan
* RGB red means sending;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
#define RF_FREQUENCY 433000000 // Hz
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
#define BUFFER_SIZE 60 // Define the payload size here
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
uint32_t color = 0x100;
int16_t txNumber;
int16_t rssi, rxSize;
void OnRxDone(uint8_t *payload, uint16_t size, int16_t rssi, int8_t snr)
rssi = rssi;
rxSize = size;
memcpy(rxpacket, payload, size);
rxpacket[size] = '\0';
turnOnRGB(color, 0);
color = color == 0x100 ? 0x10000 : 0x100;
Radio.Sleep();
Serial.printf("RECEIVED %s\r\n", rxpacket);
void setup()
txNumber = 0;
rssi = 0;
Radio.Init(&RadioEvents);
Radio.SetChannel(RF_FREQUENCY);
Radio.SetRxConfig(MODEM_LORA, LORA_BANDWIDTH, LORA_SPREADING_FACTOR,
0, true, 0, 0, LORA_IQ_INVERSION_ON, true);
turnOnRGB(COLOR_SEND, 0); // change rgb color
Radio.Rx(0);
delay(500);
Radio.IrqProcess();
