Htcc-ab02 1/2aa
I’m using the following example code with my HTCC-AB02 1/2AA both the terminal monitor and the application are using baud rate of 115200. When I press the ‘USER’ button I get no response. If I press the ‘RST’ button I get ‘Copyri’ in the Serial Monitor and that’s all? This seems like a pretty simple example what am I doing wrong?
#include “Arduino.h”
#include “LoRa_APP.h”
#define INT_GPIO USER_KEY
#define timetillsleep 5000
static TimerEvent_t sleep;
uint8_t lowpower=1;
void onSleep()
Serial.printf(“Going into lowpower mode. Press user key to wake up\r\n”);
delay(5);
lowpower=1;
void onWakeUp()
delay(10);
if(digitalRead(INT_GPIO) == 0)
Serial.printf(“Woke up by GPIO, %d ms later into lowpower mode.\r\n”,timetillsleep);
lowpower=0;
TimerStart( &sleep );
pinMode(INT_GPIO,INPUT);
attachInterrupt(INT_GPIO,onWakeUp,FALLING);
TimerInit( &sleep, onSleep );
delay(5);
if(lowpower){
lowPowerHandler();
