hi,
sorry, I thought you wanted AM01.
If it is AB01, there should be no other way.
hi,
Ok friend, got that. Thanks.
@jasonXu Hello friend. I need to read analog voltage to get resistor value with know resistor voltage divisor. Also I need to measurement the current output voltage from GPIO pin.
The problem is the hardware only accept 2.4 v on ADC. I make a voltage divisor to get down the voltage but affect my other voltage divisor.
There is a workaround to read 3.3 volts with ADC or any idea how solve my problem ?
This is my circuit but I cant work like this because the ADC cant read 3.3 volts (the GPIO voltage)
Hi @dserrano
The voltage divider circuit should be a network of pull-up resistors and pull-down resistors. For example, just like this:
In the example, the voltage on GPIO13 should be calculation like this:
Hi, did you made a SDS011 sensor integration?
