HTCC-AB01(V2) and getBatteryVoltage() always getting 0.0020
I use my HTCC-AB01 (V2) to measure temperature and send it via lora to TTN. Since I’m using a 18650 3.7V 1200mAh battery connected to the battery plug on the device I’m always getting 0.0020 as output if I use the code:
I expect that the voltage will be change over the time of a few weeks I’m using it.
Any idea what’s wrong?
