I noticed that when using external CP2102 to connect serial pins (RX/TX) of HTCC-AB01 dev board to my computer, and without the power applied to the board in any way (neither via USB nor via pins) the board boots up and sends logging data (Serial.print()) via the serial connection (clearly, there’s no enough current for LoRa, but the MCU is working).
Is there a way to “isolate” RX/TX from that “parasitic” power and not power the board that way?
