@jasonXu, would you be able to provide the 3D .step file for the HTCC-AB01?
I am creating a custom PCB that will include the AB01 and I need to make sure it can fit in the enclosure.
I checked here and was unable to file any 3D files.
Thank you.
Thank you.
Any suggestions? Even a pin layout would be helpful. Specifically measurements for the interior pins.
Do it the old fashioned way.
Take calipers, measure everything and adapt your PCB design
Sounds good, I will get to it.
I would also appreciate very much an official STEP file for both AB01 and AM02 !
Very useful when designin custom enclsures.
Hello, I have modelled the HTCC-AM02 in .STEP, it can be downloaded here
I use it with KiCAD
Christian
Very good work!
Do you have plans to model htcc-ab01 dev board? I think a lot of makers are doing projects with this board and we all put somehow on any case without a good design.
Best regards,
undeporaki
Thanks !
I think that it’s possible, I just need some time.
As soon as it’s done I’ll let you know.
Best regards
Christian
Hello, I already did it yesterday… It is a rough aprox ahaha.
Check this: https://grabcad.com/library/heltec-htcc-ab01-dev-board-1
Best regards,
undeporaki
